- Oct 29, 2004
- 5,594
- 0
- 0
I'm at the moment doing a CD drive and Floppy combo. Problems that have cropped up thus far.
1. I'm unable to boot from my CD drive unless I have an HDD installed, think it's a bios issue. bleh.
2. This is the real important one:
I've gone through about 5 nics and I'm unable to get m0n0wall to work. I mean I first started with ISA nics just for the hell of it, went into port configuration and while they were detected, they wouldn't detect the network link for me so I had to specify the lan and the wan.
Didn't work, unable to connect.
Put in two 3com 10/100 PCI nics and I run port configuration again. Run Auto detect, put in the cable, hit enter, it detects it on only one network card for LAN. Go to the Wan, run auto detect, put in the cable, detects it, if I try to switch around the LAN and WAN, it's a no go; weird. I specify the IP for m0n0wall, enable the DHCP server and specify 24 for the subnetmask, enter the IP range of 192.168.1.100-200, try to access it, no go.
Try to connect to m0n0wall remotely, doesn't work.
Get some newer cheaper nic card I stick in there, m0n0wall detects it, do the port thing and I leave it by its self just to see if I can access m0n0wall on the lan.
Tried it again, didn't work.
So, what should I do? I tried renewing the addresses on the computer but it wouldn't detect it, tried a straight through and crossover cable but it wouldn't work.
Now I'm wondering, since I don't have a hub/switch ATM (don't want to explain), shouldn't I be able to access m0n0wall with a direct link from m0n0wall to a computer? The other computer has an Intel GigE card in it and so I'm not sure if it's the root of the problem or not as I can't test it with another card.
Tried changing duplexs on the GIGe machine to half duplex 100, still didn't help.
FYI:
I can't connect the firewall to the cable modem until I can prove that m0n0wall is perfectly functional. I need to find a way to test it with out directly attaching it to the modem. Only way I can think of is to connect m0n0wall to the router and try to NAT the 192.168.1.100 address but it just won't take it which is kinda dumb in it's self.
FYI:
