I just bought a complete computer recently, and initially after booting it up and giving it the usual run thru, loop tests etc.., i didn't seem to find anything wrong with it.
Today I was playing tribes 2, and lo and behold my computer decided to give me a random reboot. Thinking it odd, and just out of curiousity I checked my cpu temp
it was a whopping 75 degrees Celcius! It eventually idled down to 55c, but from everything I've read on these boards, that still seems very high.
Well I popped the cover off my case, and the first thing I notice initially was the heatsink/fan. It looked like a mean mother to take off, so I went and consulted the manual first. After doing some research I learned the Heatsink/fan(zalman cnps 5500-cu) is only rated up to 2.5ghz.
I was able to take off the zalman and placed the retail Intel heatsink/fan assembly on(w/ some thermal compound of course). Well to my suprise the idle temp. was 70c!
For the interm I've put the zalman back on.
But in the mean time i have a few questions...
(info: p4 3.06ghz, Asus P4PE motherboard, default bios config, no overclocking on my end)
1.) Are these abnormally high temps that I'm seeing?
2.) Will a better heatsink/fan(and something like arctic silver) make a noticable difference in my temps?
3.) Is there anything else i can do(reasonably priced, and nothing fancy like watercooling) to bring down the temps?
4.) If so, what are your recomendations on heatsinks/fans?
I see a lot of rave reviews on the SLK900-U and i've been thinking about ordering it, but I'm not sure what else I'd need. I know a fan is a definite(i've been looking at the Tornado as noise isn't that much of an issue to me), but then there's the screws, and different types of connectors. I figure the screws are necessary, but what about all the other accessories they try to sell to you?
Any help would be greatly appreciated, and my computer would give you many thanks as well 🙂
