Having CoD problems! HELP
Looski
13
Please someone tell me wat this is.
I went to play Call of Duty I logged into a server fine, but when it got to where I pick allies or axis it disconnects me.
The message says "Unpure client detected. Invalid .PK3 files referenced!"
Wat does this mean, how do I fix it, wat is a pure/unpure server.
The game has worked great until today, I've played multiplayer before on the same server. Some one help.
VicodiN
576
You have some kind of modified file... aka custom crosshairs, custom skins, etc.
BlueWeasel
15,944
475
The server is a "pure" server and is not allowing you to connect because, as VicodiN mentioned, you have some modded *.pk3 files in your COD directory. Once you delete the modified files (not the base .pk3 ones), you should be good to go.
