Having an odd problem
Discussion in 'Computer Help' started by BoomerD, Jan 2, 2013.
  1. BoomerD
    BoomerD Lifer
    Feb 26, 2006
    48,410
    568
    Ever since we moved in November, I've been having an odd intermittent problem.
    The PC closes whatever window/program is open and goes into shut-down mode. No BSOD, no "instant black" screen...everything shuts down in a nice, orderly manner.
    At first I suspected my dying PATA HDD, but I installed a new WD Black SATA drive and disconnected the old drive...and the problem continues.
    The system had been set up with dual boot...1 SATA drive with Vista 64, the PATA drive with XP 32.
    Currently, I have Win7 64 on the WD Black drive.
    So far, I've checked all PSU connections...everything seems good. I've removed and re-seated all RAM DIMMS, and removed and reinstalled the GPU.
    System specs are:
    Intel i5-760 stock speed
    ASUS P7P55D-E Pro
    WD Black 1 GB HDD
    8 GB Corsair RAM
    EVGA GTX460 Superclocked Graphics Card
    Corsair HX 620 psu...about 5 years old, never "heavily stressed."
    (2) Samsung DVD burners
    Dell 24" monitor (1920x1080)
    Windows 7 Ultimate
    I guess the next thing will be to run Memtest+ on each stick of RAM, but it's odd...everything worked fine BEFORE I packed it up and moved...now...:shrug:
  2. Loading...
    Similar Threads - problem Forum Date
    Hardware problems. Need some pointers. Computer Help May 17, 2017
    Occasional boot up problem Computer Help May 17, 2017
    Pc repair store-usual turnaround time for my problem Computer Help May 6, 2017
    No login option after restarting my pc Computer Help May 3, 2017
    problem with new PC build Computer Help Apr 26, 2017
  3. Ketchup
    Ketchup Elite Member
    Sep 1, 2002
    13,339
    73
    If everything is shutting down in a nice, orderly fashion, it's not hardware (alone).
    1. Checking BIOS and Windows power options is the first thing I would do.
    2. Is the any consistent foreground or background application that is running when this happens?
    3. Are you running on a UPS with software?
  4. BoomerD
    BoomerD Lifer
    Feb 26, 2006
    48,410
    568
    No UPS.
    No particular application.
    I've checked everything I can think of to check.
    No dumps to troubleshoot from.
    The motherboard has the latest BIOS available from ASUS.
    It's odd as hell. If it was my earlier HDD's, it should be gone with the new HDD (only) connected, but it continues.
    It happened with both earlier OS's (Vista 64 and XP Pro) and with Win7 which was just installed today on a brand-new HDD...which is what makes me think it's hardware caused, but I'm unable to track it down.
    The only things I HAVEN'T done is to run Memtest or to re-seat the CPU Cooler. (since it's a BIG cooler, I used some twist-ties connected to the case to support it during the move to prevent it from stressing the motherboard/socket.) Temps all seem to be at their normal values. (CPU runs about 30C)
  5. Ketchup
    Sep 1, 2002
    13,339
    73
    Anything in Windows logs around the time of the reboot? Maybe pointing to an application?
  6. BoomerD
    BoomerD Lifer
    Feb 26, 2006
    48,410
    568
    Nope. Like I said...this has happened now in 3 separate operating systems on 3 separate HDD's.
  7. Ketchup
    Sep 1, 2002
    13,339
    73
    Does it stay up the same amount of time before the next power down?
  8. Steltek
    Steltek Golden Member
    Mar 29, 2001
    1,635
    The way you describe it makes me wonder if you have some sort of software installed that is doing an automated shutdown. Have you checked Task Scheduler to see if there is anything there that might be doing this?
  9. BoomerD
    BoomerD Lifer
    Feb 26, 2006
    48,410
    568
    Nope...sometimes it will happen several times in a row, other times, it'll go a day or more before shutting down.
    Nothing there that should do this. It's too intermittent/random to be something scheduled.
  10. jolancer
    jolancer Senior member
    Sep 6, 2004
    469
    try a surge protecting power strip, just for example: http://www.amazon.com/gp/product/B00...4?tag=at055-20
    and change outlets if you suspect the one your computer is currently connected maybe near or sharing the same line as high power appliences including ACs/Electric heaters/mini fridges etc. depending how old or type of place, u can desifer if neccessary witch outlests are shared by playing with your curcuit breaker pannel, just disconnect sensitive equipment such as your PC beforhand.
  11. mlc
    mlc Senior member
    Jan 22, 2005
    445
    if it's doing a "clean" shutdown, that would imply a software related problem.. like a UPS driven program or task scheduler, as suggested by the other poster... or possibly some malware /virus on your system... I would run a virus scan, and then try something like malwarebytes or spybot to see is something unwanted is running on your system...
    if it's just a shutdown, then that could be hardware... weak/faulty PSU, and heat are likely culprits there... so check your temps... Other possibilities would be a bad case power switch , bad board, corrupted bios, bad cable, etc...
  12. Matt1970
    Matt1970 Lifer
    Mar 19, 2007
    12,323
    The power button could actually be doing that as well. It's rare but it does happen, especially after being shaken around during a move. Under power management you can set your power button to go to sleep. If the computer goes to sleep randomly you will know it's to blame.
  13. BoomerD
    BoomerD Lifer
    Feb 26, 2006
    48,410
    568
    I double checked the "power button actions" yesterday after installing the new OS. Set for "shut down."
    I ran Memtest86+ overnight. About 7 hours...no errors found. When I had one stick go bad last year, it started throwing errors within a couple of minutes. ALL were replaced under warranty by Corsair.
    I have a hard time believing it's a software issue. Brand-new HDD with the few programs that are installed all being fresh installs.
    OS
    MOBO utilities
    a couple of HDD diagnostic programs
    Norton 360 from Comcast (was happening with MS Essentials too)
    I hate "troubleshooting by part replacement." That's expensive and wasteful...and my budget won't allow me to buy unneeded parts "willy-nilly."
  14. Ketchup
    Sep 1, 2002
    13,339
    73
    If your sure it's not software, I like where Matt is headed with this. Try cleaning out the power plug. You could also change the way the power plug behaved from the BIOS to rule the button in/out.
  15. Matt1970
    Matt1970 Lifer
    Mar 19, 2007
    12,323
    I think you eliminated it being a software issue since it does it on multiple hard drives. Try setting your power buttin function for sleep and see if the computer goes to sleep randomly.
  16. DSF
    DSF Diamond Member
    Oct 6, 2007
    4,902
    I agree I would start here because it's easy, free, and fairly conclusive if it works.
  17. BoomerD
    BoomerD Lifer
    Feb 26, 2006
    48,410
    568
    Yeah...that's easy enough to check...
    As for the power plugs in the apartment...I don't know about the wiring behind the walls, but all the outlets were just replaced when they refurbished the apartment. Those are all brand-new. (of course, that does NOT mean the wiring isn't FUBAR'd)
  18. skyking
    skyking Lifer
    Nov 21, 2001
    17,936
    133
    A brownout or power drop would not trigger an orderly shutdown like that.
  19. BoomerD
    BoomerD Lifer
    Feb 26, 2006
    48,410
    568
    Well...the problem continues. The PC might go several days without shutting down...then it will happen several times. Doesn't seem to be any one thing causing it...happens when gaming, happens while reading threads on this and other forums.
    This is odd as hell. No BSOD, no crash to black...everything shuts down in an orderly manner. Applications close to the desktop...then goes into "normal" shut-down mode.
  20. Puppies04
    Puppies04 Diamond Member
    Apr 25, 2011
    5,909
    Seems like you need to eliminate as many culprits as possible, recheck all connections, make sure your mobo isn't grounding on the case, maybe try disconnecting the case power button and starting the machine manually to see if the problem dissapears. On a side note, what are the thermals like inside the case? Could the mobo be getting too hot and causing the shutdowns (no idea if that mobo is even capable of doing that). Memtest would rule out bad RAM however I would usually expect a BSOD not a nice orderly shutdown if one of the DIMMS was misbehaving.
    Hope you get it sorted, I know these types of problems can be a pain in the butt.
  21. C1
    C1 Platinum Member
    Feb 21, 2008
    2,026
    17
    Is it possible that your BIOS is initiating a soft shutdown because something like a PSU problem (likely voltage) is being sensed by the MB?
    Enter the BIOS from the system starting from a total shut down and just leave it run to see if the problem happens. If it does, it is a hardware issue. WHile your at it, investigate the Power Management settings, hooks and handles available in the BIOS. Check things like start up timers, soft off with power button depressed. Ensure that the selected settings make sense (check the MB manual - BIOS section of explanations).
    If the problem happens (with no OS), then redo the test after pulling off all unessential peripherals such as HDD (dont need it to boot to BIOS), NIC card, DvD Rom, even VID card if you have onboard video option. If the system still faults, then replace the PSU as a last resort.
    I know, lots of work and very time consuming, but keeps cost down.
  22. nature1ders
    nature1ders Member
    Jan 19, 2013
    58
    RMA the mobo
  23. BoomerD
    BoomerD Lifer
    Feb 26, 2006
    48,410
    568
    Having another "issue" lately. I'm suffering from severe "USB lag."
    Keyboard (wired) and mouse (wireless) are all slow in reacting. I can type a couple of words before the characters show up...if I mouse over something, it can take several seconds before the link reacts or the cursor changes from the "|" to the arrow.
    I've updated the chipset drivers for the board, uninstalled and reinstalled the Microsoft drivers for both keyboard and mouse, nothing obvious...like viruses, malware, etc...FWIW, it also does this with a wired mouse.
    Doesn't matter whether things are plugged into the USB ports directly on the board, (rear panel) or the ones on the front case panel.
    Any thoughts?
  24. denis280
    denis280 Diamond Member
    Jan 16, 2011
    3,409
    the system shutting down.is that fix! otherwise i would say the mobo.after reading all the above.that is my conclusion.
  25. corkyg
    corkyg Elite Member<br>Super Moderator <br>Peripherals
    Mar 4, 2000
    26,429
    67
    Following with what C1 said, there is a setting in some BIOS's that tell the system to shutdown on any error. Have you checked that?
    Since BIOS settings are firmware, it would affect any attached boot drive.
  26. BoomerD
    BoomerD Lifer
    Feb 26, 2006
    48,410
    568
    :hmm: I don't think it's set to do that...but I'll have to go wander around in the BIOS again to make sure.
