Having a problem backing up "The Pusuit of hapiness"
Markfw
May 16, 2002
27,100
16,015
I have tried anydvd, dvdfab platinum and dvdshrink, it beats them all.
Just hope the kids don't destroy it before I get it backed up.
Any ideas ?
matman326
13
ok this dvd and a few others like "stranger than fiction" and "Casino Royal" gave me some fits. The easiest way to do it is use ripit4me, with dvd decyprter, and fix vts and then run the end result through dvd shrink. It is important to note that you will want to turn off anydvd before you start this as it is not needed for this task. If you need more help just ask but thats all the software you need.
