I haven't put together a PC in ages... it's been closer to a decade than I'd like to admit. Therefore, I need some AT opinions. Heck, maybe I completely got something wrong. I wouldn't be shocked.
Anyway, here goes.
Thermaltake Dream Tower
Thermaltake W0022 Purepower Butterfly ATX 12V 480W
MSI K8N NEO4 Platinum nf4U
AMD Athlon64 3500+ 939 with a Thermaltake A1772
Mitsumi Floppy 7-in-1
SAMSUNG 120GB SATA (haven't heard anything bad about it... yet. And it's cheap!)
Corsair Value Select 184 Pin 512MBx2 DDR PC-3200
Likely a 6800 vanilla...either Leadtek or MSI 256 PCI-E
And some random, on-sale DVD drive
How does it sound? If you suggest something like a 6800GT or an SLI board, something else has gotta go... my budget basically allows for this setup and nothing more. So basically if one higher price component goes in, another has to become cheaper.
Anyway, are there any comments on noise, heat, speed, incompatibilities, etc.?
A sincere thanks to anyone that helps out, or even to those that simply don't bash. 🙂
Anyway, here goes.
