Have you used Netgear XE102 wall-plugged Ethernet Bridge?
ub4me
460
I just saw it at bestbuy. Click
Has anyone used it before?
How does it work? Will it work between two small building that are side by side?
Thanks!
JackMDS
29,554
430
These gizmos work between electrical outlets that are connected together to the same electrical panel. (The electrical panel would be connected to the Utility feed or similar source).
Unless the two buildings are electrically connected together (which is highly unlikely, and probably against the code) it will not work.
