Have You Ever Met This Problem~~????
dgseik
59
this is the second time i met with this problem....its kind of weird problem....and happended in both not same type of OS and harddisk (xp and win2k)...I have a .rm file that can play smoothly when i double click it but the problem is i can't copy this .rm file to another location..neither in its own harddisk or other places like desktop. i've try using external usb 2.0 casing and also secondary master to copy the file but it won't let me copy...the error message is what I/O error...it's weird...can play smoothly but can't copy...another thing is..there are some .rm file that are in the same folder..they have no problem with copy and paste...its there any solution to fix it??:confused::confused::confused:
Kadarin
44,296
16
I have a similar problem with two files on one of my drives. I get no errors, but the copy process just locks up partway through. I tend to think it's an hdd problem of some sort, but the file plays fine.
dgseik
59
ya..at first i also think of hdd problem but is it possible that there are 2 not same type of hdd(seagate & maxtor) had a same problem (hehe but not same type of file...) ??
uncleX
73
I'm going to guess it is an illegal file name. I don't know how the files get to be named with illegal characters, but I have had it happen to me. Obviously I didn't create the files with the illegal names. Windows won't let you. There are things that can be done at the system level that a user cannot, I guess. What will happen is that Windows won't copy the file because it won't create the illegal file name. You could try renaming the file, but I don't know if Windows will allow that either.
For instance files are not supposed to have names with ?,*, or \, and a lot of characters that can't be typed.
But don't forget to check the disk for file errors.
A while ago I had a lot of mp3s that wouldn't copy over the network, although they would from one part of the HD to another. Other files in the same directory would copy fine and the names of the files looked OK to me. I tried it several times, so it wasn't a fluke. And it was the exact same files that would not copy. If I changed the name, they would copy. More recently I tried copying the whole lot over the network again. No problem. Jeez Windows is fun!
dgseik
59
i do try rename it but it didn't work as well. and another thing is the file had the same name with others but different episode...i dunno why only that episode cannot copy...huh...mayb your're right...windows are fun..and crazy...hehe:)
