Have W2K pro currently, should I install XP pro ???
xcaddict
17
I have Win 2000 pro installed on my machine and have a disk with XP pro, should I install it. The W2K works OK, though it freezes randomly in any program on occasions (about one in every 5 hrs use). I now have a digital video camera and hear that the Microsoft Video program is good but only works on XP.
If I install XP, can I just put it on without deleting?uninstalling W2K and will it pick up the current desktop and settings I have currently.
If I did install XP would all my current programs still work or do I have to reinstall them, eg: photoshop 7, office, ACD (photo program), nortons systemworks, etc.
All advice appreciated as I just do not know what to do on this issue.
sykopath79
458
You should not have any problems upgrading to XP, and if you're wanting to use Windows Movie Maker then you have to get XP (or else downgrade to the hell-spawned WinME). There is certainly MUCH better video editing software out there than Windows Movie Maker, though. Personally, I tend to prefer XP Pro over Win2k on any PC with at least a 1 GHz CPU and 512+ MB RAM.
You can perform an upgrade installation to XP, which leaves your user profiles, application installs, and such intact, but it can sometimes run a bit slower than a clean install, and occasionally you'll run into a program that doesn't like you after the upgrade (seen more often with Win9x-to-XP upgrades but it could happen with Win2k also).
I always prefer a clean OS install over an upgrade. It is more work, since you have to reinstall your applications and get everything looking & feeling "just so" all over again, but it has its benefits in performance and stability.
All the programs you mentioned should work just fine in XP. XP has a lot of the functionality of ACDsee built in so you may or may not want to keep ACD. If you do opt for an upgrade rather than a clean install, I would recommend uninstalling Norton SystemWorks beforehand & then reinstalling it after the upgrade.
If your system freezes a lot, you may also want to be sure that you don't have a hardware problem. Run a program such as MemTest86 or PC-Check to diagnose your CPU/Motherboard/RAM/Hard disks, as hardware problems can cause system crashes/lockups also, and changing OSes will not fix that kind of an issue.
