- Apr 24, 2001
- 9,064
- 0
- 0
OK
Problem #1
When i restart my system, My moniter settings do not stay. The screen will change size, Not the resolution but the actual streched size of the screen.
Is there anyway I can fix this. I have a radeon 700 in my system TEMP. till I get my ti 4400. Is this some problem with the radeon or what (I have the latest drivers).
I have tried changing it by my moniters controls, and by the radeons size changer.
PROBLEM #2 {NEED HELP REALLY BAD WITH THIS}
My hard drive made my comp frezze up last night. NOTHING WOULD OPEN UP FROM MY DESKTOP AND THE TASKBAR WOULDNT COME UP.
I had trillian open so i moved the box around and it but 1 more screen on there everytime I moved it. So I shut the computer down.
When I restarted I got a beep error, saying "Primary Master {Which is my HD} Fail. Please restart".
So i took the hard drive into my parents room and put it in their system, IT WORKED FINE. NOT booting up though but as a second HD.
I took it back to my system and got the same error. So i went into the bios and let it auto detect it. Then restarted and it worked fine. This morning when i got up and turned
The computer on It gave me the same error so into the bios i went. After changing it, it booted up fine.
I just bought this drive yesterday. Its a WD 40 gb 7200 RPM, SHOULD I TAKE IT BACK TO Circuitcity? If i do will they take it back, will they accpet it. Since it works part of the time? What should i do. Is there any program that will let me test the drive throughlly (sp?) lol.
Thanks for your help.
Josh
Problem #1
Josh
