Have to wear a medical monitoring device, will be going thru TSA with it
thestrangebrew1
4,116
799
My daughter has to wear a heart monitoring device for 30 days to collect some data on some issues she's having, but we fly out to Tx Christmas day. What's the protocal for something like this when going through TSA? Do I need to contact them in advance for anything? Just tell someone when we're lined up about her device? Will they make her take it off? How does something like this work?
Dec 10, 2005
29,403
14,895
I think it depends on the device. If it's removable, you could probably remove it for the few minutes the screening will take. If it isn't going to be removed, you'll probably want some sort of medical documentation to grease the screening wheels.
thestrangebrew1
4,116
799
Yea we'll have to contact her dr. about it. He said only remove it for showers, otherwise keep it on. A few minutes shouldn't hurt just to get through screening though I'm thinking.
Dec 10, 2005
29,403
14,895
Yeah, that's probably what I would do too. Probably easier to just remove it for a few minutes than expect them to understand a medical letter.
Reactions: Captante
blackangst1
22,902
2,359
I have had an insulin pump for about 20 years, and I just ask for a pat down. Not that big of a deal.
13,971
Something electronic strapped to the body might raise some pretty serious red flags lol. I would probably look at driving instead to be safe. Airports are probably going to be an insane zoo at that time of year anyway. Seems like that amount of stress is not worth it.
I'd also worry they confiscate it, I imagine it's not a cheap device. The TSA are not exactly known for being reasonable or open to any negotiation.
Pohemi
10,921
17,039
The last few times I flew, I simply explained to the TSA staff that my insulin pump could not go through the backscatter xray machine, and I needed a manual pat-down. They didn't have any issues with doing it.
I've heard of people obtaining letters from their doctor for traveling when needing special accommodations or for special medical devices, but I've never bothered.
To the OP: find out if there is any risk or danger of the device being exposed to x-ray radiation. If you aren't sure, just don't let her go through the backscatter scanner. They can do a manual wand scan and/or pat-down.
Just ask for a pat down - say medical device, and point to it.. it will take a bit longer but it will be fine.
thestrangebrew1
4,116
799
Thanks guys. I watched my wife put the patches on her it didn't seem too difficult but I'm still going to ask for the pat down for her.
Reactions: Pohemi
