paperfist
Its not really inefficient from the boiler perspective, it will run summer or winter. Perhaps you mean there would be more idle time since its only duty in the warmer months is to make heat for hot water. There are also issues with the chimney where the warmer summer weather will result in a weaker draft may affect boiler performance. I have never seen a forced hot air system also make water unless a boiler was present to exchange heat to the forced air component of the system.
The thermostat in this situation calls for heat and the controls fire the boiler to circulate hot water through the heat exchanger zone plumbing and then turn on the blower on the forced air system to convey heat to ducts. In the summer, there should not be a call for heat and the forced air component can be used for cooling if needed. If the boiler is also sending heat to an indirect hot water heater, that is plumbed in as another zone and treated just like any other zone. Usually, hot water zone is set as a priority zone and the boiler will favor this zone to satisfy demands for hot water before returning to heating the structure.
No I meant compared to a boiler a forced hot air system would seem like an inefficient way to heat water.
I have a indirect hot water heater on my boiler. It doesn't take very long to heat up the water and then shut off. I guess if you compare to a stand alone hot water heater that's running quite a bit to keep up with the demands it's not inefficient.
So you're saying a forced hot air system used to heat water also has a boiler?
