- Mar 13, 2000
- 157
- 0
- 0
finally growing tired of my via boards(aopen ax63 pro)sluggish performance,i swapped in my ol ax6bc,after reading annands article about running a bx at 133+.i had given up of running my 600e at 800 on this board,because my creative tnt2 ultra apparently did not like running at 89mhz..i then read the article and discovered that my card had sidebanding enabled,and with that failed at 89mhz..according to the reviews in the article,creative tnt2 ultra work fine at 89mhz and 148(at least the one annand had did!)..ok.so i fired up the ax6bc(without reinstalling windows,just swapped boards,it seemed to go without a hitch..no conflicts or missing stuff in device manager,but i think the via drivers are still in there,maybe that might be a prob..),set the agp jumper to 2/3,disabled sidebanding with creative agp wizard,set the chip to 800(does 900 stock) in bios and away i went..got into windows,all my settings intact(thats why i didnt reinstall win 98se),went into device manager to make sure all the bx stuff was there annd via stuff gone,which it was..no problems so far..done a run through of 3dmark99,2000,final reality(my god! i didnt know what i was missing!i just wish via would get their act together!)all went without a hitch..i was happy..real speed at last!!!!! so then i went on the net and surfed awile,still no problems THEN........i went and run another round of 3dmark2000.it locked up in the first test(didnt before that)..i reset,tried again..same result..ok..i then tried 3dmark99 it completed a 20 min looping process..wtf?!? cool,i thought,i,ll try 3dm2k again..bingo it locked in the first test again!!! atthis point,i thought it might just be 3dm2k,as 3dm99 had no probs..i then tried final reality and guess what?it freakin locked too!!!now im at a loss..i have sidebanding disabled,agp forced to 2/3 and according to annands article,i should be running at 800 with my creative trouble free..it must be agp related,as the pci is running at spec.what do you guys reckon? could it be that my ultra just might be one that dont like 89 mhz??? or could it be something else? please help!!!as i would like to run at 800 on this bx board..im running my chip at 600 at the moment and it benches just a little slower than my old via at 800!!! could the problem be that i didnt reinstal windows? any info much appreciated...thanks all,
celeron550
celeron550
