The kit came with the enclosure, the USB converter deal, and a hole to plug the power into. Didn't come with an external "wall wart" though. Just wonderin' what type of power adapter I need to be using.
If there are 2 usb cords wired to it then the enclosure gets its power directly from USB so no power cable is needed. It would help knowing which hard drive enclosure you have.
