Have a strange video problem, not sure how to describe it...please help...
hansolox2
4
Specs:
Athlon II X4 630
2 gig ram
Win7 ultimate 64 bit
his hd5770 video card
Olevia 27 inch lcd connected with vga cable running at 1280 x 768.
Catalyst Version:
Driver Packaging Version 8.723-100406a-098769C-ATI
Catalyst™ Version 10.4
Provider ATI Technologies Inc.
2D Driver Version 8.01.01.1016
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0001
Direct3D Version 8.14.10.0743
OpenGL Version 6.14.10.9756
Catalyst™ Control Center Version 2010.0406.2133.36843
I am having a strange problem and I am not sure what the term is for what is happening. It seems to happen in all games I play. For instance, when playing Gears of War, when I look up and down, a strange wave rolls through the screen almost like when you get interference on a standard television. The wave does not roll continuously but rather moves at the rate that my character is moving and usually only appears when I am looking up or down or turning quickly. Is there a term for this? Does anyone have any suggestions for fixing this?
hansolox2
4
is this function of the monitor or the video card? I have tried 3 different monitors: 15 inch samsung 152n lcd, the olevia, and a magnavox 32 inch lcd tv and it happens on all three machines. I tried setting the "Wait for vertical refresh" option in the Catalyst settings to "Always On" and it did not make a difference.
Sylvanas
3,752
Under 'Wait for Vertical refresh' select 'Always on' in the drop down menu. If this doesn't work google 'D3DOverrider' and try that.
hansolox2
4
I'll try that. I just found the setting in Gears of War to force VSync and it is still happening.
toyota
12,957
I know when I had an ATI card that vsync would not work in several games and whether using the in game or control center didnt matter. yeah you will probably have to use D3DOverrider.
Madcatatlas
1,155
lol..what is this then, a topic which is "fixed" before i even see it..
Anyway, still got a post off...:p
