- Nov 11, 2008
- 3,204
- 52
- 91
I just bought a GTX 580 to replace my GTX 460 in anticipation of Skyrim.  Its great, but its the Galaxy model with the Arctic Cooling Accelero Xtreme on it and all the hot air is getting dumped in my small case:
http://www.newegg.com/Product/Produc...82E16811112218
Even with the 140mm optional blow hole lid it can't keep up. While playing an intensive game the card is hitting over 80C on auto (and staying there) and the power supply is going nuts trying feed it (lots of squealing and heat produced). Even with the fans on max (which is 85%) the temps are in the mid to high 70s. With the side panel off the card is hitting 65C at 60% fan speed and the power supply is quieter.
Obviously I need a roomier case with better air flow. Any suggestions for larger, cooler case? I would like one with clean lines - not too busy or silly looking. Thanks for the suggestions! Oh, budget of up to $200.
