have a Geforce SDR, should i replace it with a MX?
faye
2,109
Hi, i think my Geforce SDR is having heat problem. I don't see a visual problem yet, but when i touch the ram, it is so d*mn hot.
So i guess replacing it would solve the problem :)
Is it worth to be replaced by a Geforce MX?
SDR is a little more than MX($$), but is MX a little faster?(and a little visual quality improvement?)
MustangSVT
11,554
12
u probably will see some improvement, but i dont think it'll be much better then what u have now.
get those ram sinks. they'll keep it cooler or help u clock em higher
BFG10K
22,709
3,002
Then there's no problem. Just don't try to overclock it and you should be fine. If you are that worried about it you can get a heatsink or a fan.
No, not really. Unless you need to run two monitors at once.
Bartman
as far as I know there is no way the ram should be getting that hot overclocked or not.. so hot you can't touch.. that's a problem!
Bart
BFG10K
22,709
3,002
If he is running at stock speeds and has no visual artifacts there is no problem.
Like I said before Faye, get a heatsink or fan if it bothers you that much.
