Hauppauge WinTV PCI Won't work, Help!?
simms
I just got a Hauppauge WinTV PCI card, and I got the drivers from (http://www.hauppauge.com/xp/software/xp_wintvpci.htm) and I got the WDM Driver and the WinTV2000, and I even got DScaler which I heard was good, but it's not working.
When I try to run WinTV, I get a "Can not locate Capture Fileter (Hauppauge WinTV Capture), then a "Can not build Filtergraph" then a "WinTV Initalization Error. hTV=0". I try to use DScaler but all that does is give me a blue video screen (not the BSOD, but just a VCR blue screen) no matter what settings I change.
Any help/more info, PM me! 🙂 Thanks
Simon
Just out of curiousity, do you have a webcam or a scanner?
My Hauppauge whined and moaned about having such devices in addition to itself.
