Hauppauge Remote problem
Spydermag68
I just got the WinTV-PVR-150 and using two monitors. The problem is I have set the TC to the second monitor so I can work on the primary monitor. If I want to change channels I have to click on the WinTV in the task bar or click on the WinTV2000 window before I can use the remote. The only button that works when the another window is the active window is the mute button.
Any way to get around this?
Thanks
Doubt it. Throughout the history of Windows, hardware input (keyboard, mouse, infra-red remote control, etc) works only with the currently-active window.
What sucks is that Mute works. I assume it doesn't mute the application, it mutes the Windows audio sub-system...which kinda makes the multiple audio streams design of PCI soundcards useless.
