Hauppauge PVR-350 Video/Audio-in delay?
artemicion
When I try to hook some source to the video/audio inputs of my PVR-350, there's about a 1-second delay, making it impossible to play video games. Is this supposed to occur? Why does this occur? If there's no way around it, it seems kind of lame . . . the whole reason I bought the PVR-350 was so I wouldn't need a TV. But if it can't play console games, that's like half the reason for owning a TV. Weak.
It has to encode it to the hard drive, you need a passthrough or VIVO function. I'm not sure you can do this with the 150/250/350 line.
Yep. If you don't have a pass-through, just go to the display inputs and switch it there.
Odd, I myself have a Leadtek WinFast TV2000 XP and I use DScaler.
I have no problems playing console games. I'm pretty sure our cards are similar, try DScaler out and see if that helps. Heres the link.
Other than that, I don't really have any advice. I'm sure you can get it to work like I did.
