Haven't used an Intel CPU since 1998 so I'm completely new to overclocking on Intel.
-When I set everything to Auto, Auto, everything works pretty much as expected. At full load, CPU-Z shows 1.104V, and the CPU Turbo Boosts to 3.7 GHz. I guess the stock voltage of my CPU is 1.104V, then.
-I then left everything at Auto and increased the multiplier to 42. The system booted, but showed a constant 4.2 GHz, at 1.36V 😱. Did the motherboard or the CPU pick this voltage? I thought, if I didn't change anything, it would just use the stock VCore?
-I then changed all the Turbo multipliers to 42 and set the CPU multiplier back to default - The CPU now correctly throttles to 0.8V and 800 MHz at idle. At load, it has decided to run at 1.1238V for whatever reason. I didn't change anything as far as CPU voltage since I wanted to try it at stock voltage first.
-I then used "voltage offset" instead of defining the voltage. I set it to -0.05V. Voltage at full load (8 threads Prime95) is now 1.189V. This makes sense since without voltage offset, it was at 1.1238, a difference of 0.0652V (close enough to 0.05V). But why did it base this offset on the 1.238V I was getting at 4.2 GHz Auto, and not the 1.104V at stock? What causes this auto-magic bump in VCore from just increasing the multiplier?
Also, this affected idle - at 800 MHz, it now idles at 0.65V instead of 0.8V (~ 0.05V offset again...). This may cause stability issues at idle...
-I then set the Turbo multipliers to 40x, no voltage offset. The powers that be, decided to set my VCore to 1.1233V.
What's the proper way of defining voltages? I just want to bump the full-load voltage slightly and try increasing the full-load multiplier to 42-44x without affecting idle frequency and voltage... But the VCore seems to live a life of its own.
