Haswell E De-Lidded
What's very concerning to me is the very low turbo speed of 3.3GHz, even with IPC improvements HW brings to the table over IB it's going to be slower then 4960X in ST workloads and low-threaded workloads like games. Compared to 6-cores HW it's going to look even worse. On a positive note I think that the low stock clocks are attributable to the abysmal stock cooler which I guess haven't changed at all compared to previous CPUs with that TDP. With a proper cooling it should pass 4GHz with ease but anything over 4.5GHz might require a custom loop. I don't know why enthusiast whose most stressful workloads are games flock to this CPU. 6c/12t is going to be plenty for games for the foreseeable future. I think the only reason is e-peen. For the wast majority of users Core i7-5930K clocked at 3.5GHz base/ 4GHz boost is going to be faster, especially in games.
That's 16% higher base frequency and that's a lot. 16% higher frequency should be better then 33% more cores in a majority of contemporary workloads. As for overclocking crowd, for those with custom loop coolers that would allow the 8 core monster to stretch its legs it should makes sense as that frequency gap should erode. IMHO both CPU should hit a wall well before 5GHz, the 6-core version maybe getting 100-200MHz more.
hope you are right about the low clocks being limited by the stock cooler matching.
for some of us that "actually" demand maxed out eye candy running quad flagship gpu playing very demanding online first person shooter. this is no e-peen. every IPC counts. it is a matter of getting the job done.
only if aftermarket cooler or water loop can bring up the clocks. then it will be a winner. for now IVB-E looking really good overall.
Yeah, the big question is always the OC capability. IB-E was not terribly exciting in this regard. I'm not holding my breath.
Considering what they do to engineering samples, I would not be surprised if that ES had been damaged already by the massive stress tests they usually put them through.
What matters at this point is, can the 8 core version overclock to 4.5 GHz, assuming enough cooling is available? If it can do at least 4 GHz, maybe. If not then it's not useful as a gaming chip and the 6 core is a better buy.
They raised the TDP, and still had to keep the clock that low. 4GHz on all cores would be a golden chip. Making a custoom turbo profile would be better for gamers who want this CPU. Broadwell-E should be a significant improvement, though.
Well let's make an assumption. You have a 5% chance of getting a "bad" core. That means a 95% chance of getting a good core. Let's define a bad core as say, need a ton of voltage to get to 4.5 GHz on Haswell 22nm. So you have a 0.95^4 or about 0.81 chance of getting a decent Haswell 4 core. Looking at the overclocks around, 20% not making 4.5 GHz is probably likely. Haswell seems to top out at 4.7-4.8 GHz no matter what on air, even with a delid. That means that the 6 core will be 0.95^6 and 8 core will be 0.95^8.
There are other issues of course. Not everyone on overclocking websites even have the same level of experience/skill overclocking.
All 8 cores on 4GHz is probable I think, assuming enough cooling. The problem is going to be getting all 8 cores to 4.5 GHz on water, which I doubt many chips will be able to do.
I'm not as optimistic about Broadwell. All those delays probably mean that Intel is having yield, heat, and leakage issues. That in turn probably affects the overclocking headroom those chips will have. For Broadwell 4 core to break even, it must be able to run at least at 4.4-4.5 GHz, assuming it's 3-5% faster clock for clock than Haswell DC, which ran at 4.7-4.8 GHz. The only thing Broadwell E will probably offer is more cores. All in all, I expect that Broadwell will be like Sandy to Ivy. Not much of an upgrade and perhaps even a downgrade in some cases.
I don't expect more cores for at least 5 years. With Skylake, though, the middle SKU might be 8 cores.
have to conclude it was done intentionally, or out of ignorance of the presence of solder, or because of the lack of a simple tool like a small torch or even a heat gun.
Looks real, but very lucky to break the chip this way. That's the CPU die stuck to the top of the heat spreader (and the balls under the die not coming up with it - that's been my experience)
Considering Haswell-E is going to be a native 8-core die, it's probably one of the early ES chips where they are harvesting dies for the low core count chips.
Haswell EP is 8/12/18, I believe.
Devil's Canyon I think has (mostly) addressed the issue, although there is still some grumbling around about having to delid. The gap is not as big I think with the 4790Ks, they use somewhat less power, and they run mostly cooler.
The issue I see is that even with the gap addressed or if you delidded, you still did not get much more than say, 4.7-4.8 GHz on air no matter what on air. And getting the last 100-200 MHz saw power consumption skyrocket.
What it suggests is that even with the solder, I think many of the E versions will struggle to make 4.5 GHz.
agree. This seem to be an inherent limitation of the process.
I would even go as far and say that the 4790K will be even faster in a lot especially older games, say Starcraft 2.
In games that utilize only 2 threads 4790 should be the fastest except for the very cache dependent games with WOW being the biggest offender as far as I know. Do you know of any other games that behave like that?
This benchmark shows that which CPU ends up fastest is very workload specific so you can't just shell 1000$ and have the best CPU regardless of workload unlike the past where the fastest and most expensive CPU was the fastest everywhere with few exceptions like where OCed celeron was faster then OCed P3 because both could be overclocked to similar speeds and some workloads proffered smaller and faster cache then bigger and slower cache, but now the situation is not even clear at stock, depending on the workload as much as 3 CPUs can trade places.
Anyone else remember when Intel changed from using thermal paste to solder back with Prescott, and people complained about no longer being able to delid their Pentium 4s and cool them directly from the die? Times have definitely changed.
As for the 5960K, I guess it's not really much of a surprise that the base clock's that low, but isn't this the kind of chip that would really benefit from being able to turbo up several speed bins (i.e. to ~3.8GHz) for single-thread apps? Or do the extra cores just generate too much heat even when they're idling?
Cool story, yes they increased power consumption until they needed solder and now they are lowering TDPs to old Pentium 2-3 levels, the limit appears to be around 100W for solder vs paste.
I'm surprised too at the staggering low turbo of the 8-cores: is there some pratical problem to have the same 4GHz single turbo as the 4960X?
What the heck this is slower than a i3 in single... unless overclocked of course.
Regarding all the pessimistic comments that announce no more than 4-4.5GHz overclock: is that because you saw the low stock speeds or logic reasoning like thermal constraints etc? Because the soldering and the huge die seem to point elsewhere: it's a die-harvest from 12 core chips and all that dark silicon (the 4 disabled cores) should help a lot to spread heat.
Also I'm curious if the 6-core variants are a different die or have 6 cores off...
That early engineering sample chip might have four dark cores, but final silicon will have 8 cores natively. The low end chips usually get taped out later, so Intel makes chop versions of higher end chips so developers can work on them.
