So now I've seen the details for IVB-E and been quite disappointed (plus cost wise it's probably better) I've decided to switch to Haswell.
I realise nothing I am running would require the use of 6 cores/12 threads however I was more interested in the amount of RAM I could chuck at the 2011 board. Portability was a factor so I was hoping to have less boxes to lug around the country with me.
As I'm going Haswell and am limited to 32GB I've bought a HP 54L and added 16GB RAM to it as a standalone ESXi server. Although I may rebuild it as the primary FreeNAS server.
I was thinking of something like the following:-
CPU:- Intel 4770 £240
Prefer a motherboard that support VT-d (e.g. Asrock Q87M Pro) although I read some Z87 chipsets support it and I'd prefer one of those.
32GB RAM :- Kingston 32GB DDR3 1600MHz HyperX Genesis XMP £220
PSU:- XFX Core Edition 750w 80+ Bronze Captive PSU £80
Boot SSD :- Samsung 840 Pro 128GB £110
VM SSD :- Crucial 512 GB M4 £280
Storage HDD :- 2TB WD Red WD20EFRX RED x2 = £170
Current case is a HAF 932, would prefer something smaller if possible.
1. What YOUR PC will be used for.
PC will be a jack of all trades.
Machine is on 24x7
Streaming films to the rest of the house using Serviio
Playing games
VMware lab (at least 12 hosts) running on VMware workstation with at least 1/2 nested esxi boxes*
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
£1500 (not including the monitor)
3. What country YOU will be buying YOUR parts from.
UK
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
www.amazon.co.uk
www.scan.co.uk
www.ebuyer.com (if they have a deal on)
www.dabs.com (if they have a deal on)
5. IF YOU have a brand preference.
Intel CPU
6. If YOU intend on using any of YOUR current parts.
No.
7. IF YOU plan on overclocking or run the system at default speeds.
Will not be overclocking
8. What resolution, not monitor size, will you be using?
Probably 1920x1080 (27")
9. WHEN do you plan to build it?
Next 2 weeks
Thanks for reading.
Regards
Machine is on 24x7
Playing games
UK
www.amazon.co.uk
www.scan.co.uk
Intel CPU
No.
Next 2 weeks
Thanks for reading.
Regards
