I just bought i5 4570, Asus Z87-A and Chieftec BPS 750W c2, it first boot it refused to post, no beep and CPU defect led is on, I presumed bad mobo or CPU
After 5-6 power on/off from case and from wall it managed to post fine, tested stability and I put 2x 7950 at max load all just fine
After first power shut down, again no post, when it manage to post (I need to do a power off from wall and few start up) i get bios message, Overclocking failed loaded default??? (no OC mobo is at default), I tried disabling C6 and C7 same problem, also i tried removing all extra HW, leaving just ram and integrated GPU but same happened
Then i switched old PSU LC Hyperion 700w and it works gr8 I am using it for the last 24h no issue???
Also i did a quick test with Sandy bridge mobo+cpu+ram and no post issues with Chiftec BPS 750w, but i did not use any high end GPU
Is this PSU compatibility problem?
