haswell and cpu cooler
Because the LGA 1150 socket keeps the same mounting hole spacing as the current LGA 1156 and LGA 1155 sockets, many newer Noctua cooler will not need the mounting kit upgrade, and can simply be installed into the Haswell machine as is. In other words, if the heatsink worked with your Lynnfield, Sandy Bridge, or Ivy Bridge-based system, it will work in a Haswell system as well. According to Noctua, the following coolers are already compatible with Haswell:
NH-C14, NH-D14, NH-C12P SE14, NH-L12, NH-L9i, NH-U12P SE2, NH-U9B SE2
http://www.pcper.com/category/tags/heatsink
