has anyone used or heard of Motor Silk Oil Additive?
funboy6942
15,356
413
FOUND THIS IN ENGINEERING NEWS:
Biodegradable Lubrication Technology Reduces
Energy Consumption and Extends Equipment Life
Tuesday May 24, 8:45 am ET
Boron CLS Bond Revolutionizes Industrial Equipment Efficiency
LOS ANGELES--(BUSINESS WIRE)--May 24, 2005--To address the rising cost of energy and protect the capital investment of industrial equipment, Advanced Lubrication Technology's (ALT) Boron CLS Bond® is the solution to improve fuel efficiency; reduce friction, heat, wear and corrosion in engines and industrial equipment; and extend engine and machine life. Incorporating technology discovered and patented by the Department of Energy's Argonne National Labs, Boron CLS Bond®, an extraordinary breakthrough in lubrication technology, is the key ingredient in the MotorSilk® and LubriSilk® line of engine lubricants and treatments, equipment lubricants, and greases.
Prior to the development of Boron CLS Bond®, lubricant additives contained graphite, chorine, molybdenum, sulfonates and zinc/phosphorus compounds that did not chemically bond to metal surfaces, and were either toxic or produced toxic byproducts and/or corrosive acids. Boron CLS Bond®'s use of biodegradable hydrogen orthoborate (boric acid), allows it to meet the most stringent government standards and mandates worldwide.
According to Pat Desert, PhD, Director of University of Oakland's Product Development and Manufacturing Center, major improvements in lubrication technology only come along every 25 to 30 years and ALT's Boron CLS Bond® is an improvement of this magnitude.
"We have subjected Boron CLS Bond® to rigorous field and laboratory testing by the some of the nation's leading independent testing authorities," said Tom Foscue, chairman of ALT. "Test results from Herguth Labs and the Product Development Center at the University of Oakland indicate that our new lubrication technology can be a superior replacement for environmentally unfriendly, extreme-pressure and friction reduction additives."
Boron CLS Bond® Performance
Analyses from independent laboratory testing substantiate that Boron CLS Bond® provides numerous benefits including: increased mechanical efficiency, decreased equipment downtime, extended life, increased fuel efficiency (3.5-30 percent), reduced mechanical wear (up to 80 percent), increased engine efficiency, reduced friction (up to 85 percent), reduced friction-related heat (20-40 percent), and lower exhaust emissions (combined urban and highway up to 35 percent). Numerous field tests with state Department's of Transportation, construction companies and commercial fleets consistently show average improvements in fuel economy in the range of 10 to 50 percent.
Industrial Market Success
Work with Canadian National (CN) Rail began with an environmental and lubrication problem related to rail switches. Historically, used engine oil was applied once a week to all switches to lubricate them and make them easier to switch. Typically these switches required hand lubrication every week and the high traffic switches in the inter-model yards (which average 1,200 switches per day) required hand lubrication every hour.
A special version of Boron CLS Bond® was developed for CN Rail to meet their particular needs. After applying ALT's lubricant, the normal switches only require lubrication every six weeks and the high traffic switches have gone from every hour to once a week. Furthermore, ALT reformulated the Boron CLS Bond® lubricant into an all weather highly visible lubricant that can readily be seen where the applications are most heavily worn.
Products made by ALT using Boron CLS Bond® include both finished lubricants and lubricant treatments in the form of and/or for addition to the following: motor oils, gear oils, turbine oils, high temperature lubricants, greases, hydraulic fluids, aerosol thin/dry film sprays, diesel fuel and gasoline, mold release fluids, cold forge fluids, and many other custom formulated products to address specific needs.
How Boron CLS Bond® Works
In practical application, the Boron CLS Bond® technology chemically seals the host metal surfaces with a metallic boroxide to prevent corrosion of the metal and metal induced oxidative breakdown of the fluid lubricant. Bound to this boroxide seal is a 200 nanometer thick layer of near frictionless crystalline boric acid platelets that create a solid boundary layer lubricant. This extreme low friction boundary layer works synergistically with the lubricant delivery and/or dispersal vehicle (ex. motor oil, automatic transmission fluid, gear oil, etc.), greatly improving the performance of the fluid lubricant. The crystalline platelets chemically react with metal to create a nearly permanent, self-replenishing, lubricant on virtually any metal surface. The boroxide coating is covalently bound to the metal surfaces and molecules in each platelet have strong macromolecular bonds, giving the boundary layer the equivalent of 85 percent of the hardness of diamonds.
About Advanced Lubrication Technology (ALT)
During government sponsored research into advanced lubrication concepts, a discovery in 1991 by a prominent scientist at the U.S. Department of Energy's prestigious Argonne National Laboratory redefined the potential of lubrication technology. Following the issuance of the initial patent in 1995, ALT (as exclusive worldwide licensee) invested millions of dollars over several years to develop both additive and fully formulated products incorporating the key technology discoveries that now provide a previously untapped potential to a worldwide equipment market seeking greater productivity, fuel efficiency and extended useful lives. ALT has already established the capabilities of the Boron CLS Bond® technology through development of diverse applications for the automotive aftermarket and a host of major industrial companies.
Source: Advanced Lubrication Technology (ALT)
Found that on the Toyota's website.
Now if I read that correct the government had their hand in making the stuff back in mid 90's some time, then in 1999 the FTC "government" went after every oil additive maker claiming their products didnt not do what they claimed and sued them, the only one to win was Zmax, can be read here, then how convenient few years later when all the competition is gone a additive made with the help of the government, government funding, and government studies comes along.
I just see that as being rather convenient that the FTC would make claims that all the other stuff was no good, didnt work, and sued them, then this stuff comes to market and so far no one has challenged it. It is marketed to marine motors as well, which means, the sh1t had better, and must work for them to be able to see to that market along with aircraft, railroad, and a host of others that would put a lot of humans in harms way if it would fail.
I used to use duralube, I actually found it to work. I had a 78 Firebird I used to take on the highway to work all the time with a analog temp gage, it ran at 240 all the time, I changed the oil added duralube and it never went over 190. After that I was hooked with the oil additive. With my old 1987 Ford F250 the secondaries on the carb would stick open if I floored it. I tried all I could sprayed carb cleaner down it, all other additives for the fuel, I tried the duralube fuel treatment and halfway through the tank my problem went away, used it in alot of cars that failed emissions tests, that stuff, one tank, re-test and it would pass.
I cant find the stuff anywhere anymore but online. May give this stuff a try though, seems to claim more then duralube did, and I got the perfect test car, old ass 88 Lincoln Towncar with 27K original miles. Since the body is mint with no rust, and the underneath is mint with no rust anywhere, Id like the engine to last as long as I can, this stuff seems to have the backing to do so.
Reactions: ArturoGarci
spaceman
17,616
183
i heard you can run your engine on 1 fluid oz. of Motor Silk, while its encased in a block of ice rev it to 8000 rpm for 16 and a half years provided you have a continous supply of fuel.
they are firing up a couple bottles of that and slick 50 to the mars rovers.
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
A non-company-sponsored "owner's club" using a free forum software is NOT "Toyota's website".
*sigh*
At best the treatment is a waste of money. At worst it will damage your engine.
I'll say it again, if it ain't Molybdenum Disulfide, don't add it to your damn oil.
ZV
Chaotic42
34,429
1,610
If these additives were so great, they'd be in regular oil as premium blends with premium prices. Also, my owner's manual says that I should just use good old 5W30, and I assume that the engineers at Mazda aren't just making numbers up.
RU482
12,689
how many of you readers have actually had an engine fail due purely to the engine components wearing out.
Not talking about running it out of oil. Not contaminated oil from a coolant leak, but just an old age failure.
I bet NONE, under regular use
  • Love
