Has anyone tried the Invisible Shield with their mp3 player or other tech gadgets?
Atlantean
I was looking for a case for my sandisk sansa e260 and stumbled across theInvisible Shield and thought it might be a good product, watched a couple videos of the shield in action and read a few other reviews and it seems like a decent gadget protector. Anyone have experience with this company or with the Invisible Shield? Curious if they are all that they appear to be and if I should buy one.
I used a Best Skin Ever on my Zen Vision: M and it hasn't had a single scratch yet. They're supposed to be nearly identical products. IMO it's definitely worth the investment.
I bought an Invisible Shield for both my new RAZR V3m phone and my wife's new KRZR phone.
Installation is a bit of a pain and takes some patience. The shield pieces come with a tiny spray bottle. You wet the plastic, apply it, then squeegee the excess liquid from under the shield. It sounds easy, but lining everything up and getting a nice smooth finish can take a couple of tries. I ended up using some filtered water to wet the pieces after the spray bottle ran out.
Once the shield is on, it works very well. I keep my phone in my pocket and I've dropped it once or twice and it hasn't received a scratch. The shield has not come loose at all, and the pieces are so well cut that you can't tell it's on there unless you're looking for it.
The company's customer service is also excellent. In the process of applying one of the pieces to my KRZR, I tried to remove some dirt that had lodged itself in the plastic. When nothing else worked, I tried a little rubbing alcohol, which ended up ruining the plastic. I called the customer service line , explained what I did and asked how I could purchase a replacement piece. They sent me a new piece for free; all I had to pay was a small shipping charge.
Both the company and their product get my recommendation.
