Originally posted by: PurdueRy
Shouldn't be a problem provided you get a HDMI cable with a sufficiently large AWG for that distance.
doesn't large awg mean thinner cable?
or do i have it backwards?
in any event, i'm running a 25 footer from my pc to tv without problems.
Yeah AWG is one of those odd measurements where the smaller the number the larger the wire. 1 AWG is really big where as 28AWG is really small.
If you are running a HDMI cable a long way try to not bundle it with power cables and also try not to coil the cable up as it can cause reflections.
so wouldn't you want a smaller awg for more shielding and signal loss?
Smaller awg would give less signal loss , shielding is independent of the wire gauge that is up to the manufacturer.
