boxleitnerb
- Nov 1, 2011
- 2,601
- 2
- 81
Personal preference, I find 40 fps fairly unplayable on either single or MGPU.
In your first example with an average of 70 fps, why not cap it to 59/60/62/66? With an average of 70, how much of the time do you think it will be below 60?
A majority of the time (when you can achieve 60fps) it will be better than without a cap, and a small amount of the time (when fps drop below 60) it will be exactly the same as you play now, without a cap. You don't lose anything, but gain smooth ms free gameplay most of the time.
Sure, frame metering would be great and I'm all for it, but atm, you can get fluid, ms free gameplay if you have enough GPU performance.
Well it depends on the length of the minimums. As I said, for example in Skyrim there are long periods of lower fps outside and long periods of higher fps inside. Or GTA 4 with mods and SSAA - at day fps might be okay, but at night they most certainly will be lower with all the lights and night shadows. I don't mind if I have to endure microstutter for a few moments here and there, but for prolongued periods it's a nogo.
