Has anyone ever had a problem loading Soundblaster LiveWare? HELP!!!!
jkellynewyork
344
I want to adjust my new speakers with audioHQ but I cant because I was never able to install SB livware program properly. In the middle of installation it says there is not enough disk space to install this properly and I have to click exit setup for some of the applications. Because of this I am not able to adjust my sound, anyone have any ideas?
DieselMeathook
13
What OS are you using?
Are you really outta HD space or is the install just freaking out?
Are you installing from the OEM Disk that came with the SB card or did you download from Creative the latest?
I had major problems installing the SB Live software for my Platnium - it was corrupting the OS and I had to reformat several times.
Finally I downloaded the SEPERATE files and installed it piecemeal, it worked.
good luck, it sux to have a car with no gas.
You can get there from here:
Creative Labs Drivers
sMashPiranha
580
Damnit why can't Creative get thier act together. Liveware screwed my computer over about 3 times so far. They sit on thier market share and don't give a toss about the poor bastards like us that have put up with thier crap.
bacillus
14,517
if you want to use LW3 downloaded from the web then you should already have an earlier version of liveware installed on your hdd before you run the LW3 program which will automatically uninstall the earlier version. if not done this way you'll most likely get the not enough disk space error.
also empty your windows temporary folder before you start the installation! :)
jkellynewyork
344
Okay thanks for responses.
I am going to try the peice by peice install later.
I thought I was the only one having problems with this program cause I have not seen much posts about it.
