has anyone ever broken the pins on their monitor? Need Help!!
Ph33zy
944
recently broke two pins off the plug that connects my HMD-200A 17-in Sony Monitor to my graphics card. Is it easy to repair these two pins your own or does it look like i have get it professionally repaired. If anyone has ever repaired it on their own, let me know. thanx
arod
4,236
Are they completely broken off or they just bent?
If broken off how much is it to repair it profesionally? (ive never heard of anybody doing this)
ucdnam
1,059
Really easy to repair. Professionally, will cost from 30 to 60 bucks or even more, depending on where you go. you can buy your own parts from an electronic store, like Frys, and do it yourself. Cut the wire, place them in the right place, snap shut the enclosure, and you're in business. I'm no electronics whiz and I did it without problems.
mrbios
331
I've done that before. Just got an electronics whiz guy to fix it for me. Just grabbed a bit of wire. Soldered in. Back in business. You might be able to get away without soldering.
Russell "Mr.Bios" Sampson
Ph33zy
944
thanks guys...btw does it matter what kind of wire? or jus as long as the wire can find its way into the holes of the graphics card..(did that sound gross? =)hehe
