Hey all,
First off...I know I have another thread about my screwy 9600pro, but I thought this deserved a new topic b/c if other people are having the same problem (400/400), this could be an indication not to buy the $112 Info-Tek Radeon 9600pro on Newegg.
Ok, so I purchased this card on newegg. It's an Info-Tek Radeon 9600pro, listed as 400mhz gpu, 600mhz memory (DDR).
That's all good and happy right? Wrong.
I checked in AIDA 32--400gpu 400mem. If you right click the desktop, properties->settings->advanced->Adapter, it says internal [RAM]DAC is 400mhz. Under Radlinker, it also says 400gpu, 400mem. These numbers were reported under several different drivers (3.2, 3.7, 3.10, 4.4). The drivers that came with the card caused windows to crash so I never checked under those--just removed & re-installed.
Has anyone else purchased this card? Do y'all have any problems with it? (Mine is stable in windows, but won't play games.)
Y'all think I should keep trying to fix or just RMA?
Thanks,
-Eric
Thanks,
-Eric
