I set up a small ICS 2k and 98 network in my families house.
2k box had 2 100mb nics, one netgeat and one 3com.
And I setup everything to work with the 192.168.0.1 subnet.
And it worked for a short time, then had some problems, then it would present strang problems.
For example, if I rebooted the 2k box that was the gateway, the 2000 box would not have network access and it was appearing that it was trying to access the LAN for network resources.
So I would disable the LAN, then my cable access would work again, then I reenable the LAN and it works.
The second machine is a 98se box, with a netgear NIC.
To resolve the problems, I switched to a 10.10.10.x subnet and it works fine now.
Has anyone else had similar issues before?
