Has anyone clocked their memory and GPU speed on their Geforce 4 .. if so is it safe
cdub
254
I recommend browsing these forums a week or two back. Basically, you can OC your GF4, you run a slight risk when you do that, and the core/memory settings at which you arrive will be dependent on your particular card. No one can tell you the exact settings to use. Just up the settings slowly and test for artifacts. Repeat that until you find artifacts, then back off some.
ASK THE COMMUNITY
