Originally posted by: Toadster
i'm thinking that if you could route the power to the components and somehow vent the warm air out - it would be a pretty 'cool' mod of a PC case... (no pun intended, well -not much of one) 🙂
A mini-fridge will not work as a case. The compressor could never handle the heat output of a modern computer. Sure if you gut the fridge, forget about using it as a fridge, put holes for air/water cooling, yeah you could make it a computer case, but not using the case itself for cooling. People have tried in the past and all have pretty much failed due to the limited capabilities of the compressor and cooling systems used in the mini-fridges (they really have a poor design overall, just good enough to keep something cool, not cool a heat generating source.
If you do want to use something like this, well you have three choices.
1) Gut the fridge, put big intake/exhaust holes with big 120mm fans in them, remove the fridge's compressor/phase change coils, you will not be using them.
2) Custom mod the compressor, phase coils, air exchanger, refrigerant with more powerfull stuff (basically a much larger compressor, a coil that has more surface area/structure (more coils), bigger/larger/better designed air heat exchange unit, and possibly better qualit refrigerant and then maybe, you will have enough cooling power to handle the system, but then you will also need to put in de-humidifier crystals, and insulate some components to keep possible condensation from occuring
3) Don't use a mini-fridge, but a deep cycle freezer (which already has all the upgrades stated in solution number two, except for the dehumidifing crystals/protective insulation.
Well, I guess there is also option 4, which is forget about the idea in the first place.
