Hi guys!
I have e-mailed Anand Lal Shimpi several times during the last two weeks, but I've yet to recieve any response. Maybe my mail hasn't reached him? Anyway, here's the problem:
I read the review of the Pentium4 3.46EE that was posted October 31st. In this review, Anand had an AthlonXP 3200+ system and when reading the review I noticed that the performance of this system was extremely bad. Here's a link to the test:
http://www.anandtech.com/cpuch...ts/showdoc.aspx?i=2261
Now look at the results from WinRAR 3.40:
http://www.anandtech.com/cpuch...oc.aspx?i=2261&p=9 (scroll all the way down)
263kB/s for an AthlonXP 3200+? Hmm... Luckily I own a system that can be setup exactly like Anands AXP system:
AthlonXP-M 2600+ @ 3200+ (11*200)
Abit NF7-S 2.0
2*512MB Crucial Ballistix PC3200 @ 200MHz 2-2-2-10 (dual channel enabled)
Now, mine and Anand's systems have equal CPUs, Nforce2 mobos and 2-2-2-10 memory. So, how do the results from WinRAR 3.40 turn out on my machine?
Anandtech's results: 263 kB/s
My results: 398 kB/s
Now that's a difference of more than 50%!
Also, take a look at the gaming results:
http://www.anandtech.com/cpuch...c.aspx?i=2261&p=13
The AXP 3200+ performs horribly in most of the games and some simple calculations show that it would require an AthlonXP running at 2.7-2.9GHz to even match a P4 3.0E in most of those games! If Anand used the default Doom3 "Demo1", those results are way off. I know for a fact that an AthlonXP 3200+ is capable of approximately 70FPS if the graphics card doesn't limit performance.
So, that's a lot of text and you may find it stupid to bother with all this, but I find correct results to be much more interesting!
Anyway, I hope that somebody from Anandtech will notice this thread and actually take some time and explain how they got the results. Maybe there's something I have overlooked? If not, the tests need to be performed again.
Ohh, almost forgot! I have a theory on what Anand did wrong. It seems as if the tests were run with a memory divider that divided the mem frequency down to 133MHz (or 266MHz DDR). I did my own tests and my WinRAR 3.40 score went down from 398 kB/s to 256 kB/s. In other words, almost like Anands results. I also tested with Doom3 and my score was within three FPS of Anands score. With memory at 200MHz, as it should be, my score is around 12 FPS higher than Anands result.
EDIT: Sorry if I've posted in the wrong section. I didn't really see any board for site feedback or suggestions.
Abit NF7-S 2.0
