HardwareCanucks "Worst Case Trends of 2017"
walk2k
157
Thanks for assuming i wanted black over pink. That is what I will use once i get another case in 10 years or the current card reader drive i have dies.
Agreed and why do they have these closed fronts when there is no 5.25" drives? Make them like the old Antec 300 where there i a huge dust filter and it is open so those of us who want adequate cool intake air can get it. I know some cases do but not enough.
+1 Even without any intake fans I can put a piece of paper on the front of the case and it will stick there, so there's obviously plenty of air intake there.
For the side fan intake I got a snap-on dust filter.
chrisjames61
721
446
Front fans are overated anyway, unless you have HDD's you need to cool. Front is going to be closest to your head, in most cases, so you'll hear it most. I can run a back 120mm fan on full speed and barely hear it, but not so for a front fan. I use 0 front fans.
Case trends I hate - no side fan or vent. A side intake fan blows cool air RIGHT on your GPU and CPU. Right where you need it (unless you're using a radiator I guess). Also not enough or no dust filters! You put 8 fans inside a case, it's gonna basically be a vacuum cleaner, sucking up all the dust and hair from the room! Gross.... :p
Antec 300 forever! (I have 2 of them...) Top 140mm fan, side and back 120mm, no front fans (though the case can fit 2 of them.. I never use) with dust filters. My PC stays really clean inside, barely any dust after 1 year+.
Front fans are overrated? You might be the only person who I ever heard say that.
Reactions: Ranulf
Excessi0n
140
36
101
What I want is for all the case manufacturers to copy Caselabs and have a system that allows you to put fans OR 5.25" bays OR 3.5" bays up front. Then everybody can stop moaning about it.
dlerious
2,119
932
Good old Flex bays. Last two cases I bought were the Mercury S8 with pedestal. Love the case, hate the price.
