Hardware TNL problems
Yohhan
263
What is hardware TNL? I'm using onboard video, and I can't play "No One Lives Forever 2". Is there a way around this, or is it impossible to play without a different graphics card?
Yohhan
263
I think I meant T&L. And the chipset is Intel(R) 82810E Graphics Controller.
Thanks ahead.
EdipisReks
2,722
that integrated chipset doesn't have a TnL engine (that is indeed transformation and lighting), and you don't have one. the only way to get around it (that i know of) is to get a new card. do you have an AGP slot? if you do, i would suggest getting a nice radeon 8500, or geforce4 ti4200. if you don't have an AGP slot, then the best choices are the geforce4mx440 PCI and the radeon 9000 PCI (but i'm not quite sure if the Radeon 9000 PCI is out yet). good luck.
