- May 9, 2003
- 277
- 0
- 0
I'm running the following machine:
P4 2.4C at stock speed
ASUS P4P800 Deluxe (865P chipset)
1 GIG OCZ PC3700 Gold Rev.2 Matched Pair (Running at PC3200 settings 2-2-3-5)
I cannot get the blend test to pass--it crashes under 10 minutes every time I run it. It first crashed around 2 weeks ago, and to follow it up I ran memtest and discovered errors in my RAM. (I used to have Corsair XMS PC3200 1GB Matched Pair) I sent that back and purchased the OCZ. As soon as I got the OCZ, I underclocked it to PC3200 and set it 2-2-3-5. (The settings OCZ recommends.) I then ran memtest86 for exactly one full cycle (running all tests, not std, for ~1 and a half hours) and received no errors. I ran it again to make sure and got the same results. The other two Prime95 tests both return successful first rounds. I plan on running each overnight to see if either fails, but here's my question:
I know Large FFT tests CPU and Blend tests memory--why would Large FFT pass the first round of tests, and Blend fail? The memory isn't bad; I've tested it repeatedly in memtest and no problems pop up. Any suggestions? I monitored my temps and the hottest the P4 ever got on the Blend was 96 Fahrenheit (39 C), and it gets much hotter on the Large FFT test (104 F, 40 C) and no problems occur. What is unstable in my system? My chipset temps are constant too. (31-33C) Any help would be greatly appreciated. Thanks!!!
