- Jan 28, 2002
- 81
- 0
- 0
I have a IBM 60GB 60GXP 7200RPM & a Western Digital 10.2GB HDD. I have the 60GB set as the master with XP Pro on installed on the first 30GB partition, and the second 30 gb partition has nothing. On the Western Digital I have it set as the slave with Win98SE installed.
Here's the problem: :| :| :|
When I try to boot into XP Pro, my computer gives my an error saying that there is something wrong with my computer. It says check your hard disk for errors and/or corruption. Then remove any newly added hard drivers I.E. my Western Digital 10GB.
Then is has this error:
***STOP:0x0000007B (0xF7ABF640, 0X00000034, 0X00000000, 0X00000000)
But when I disconnect the Western Digital from the IDE cable and just boot with the IBM, XP boots fine, no problems whatsoever.
And if I boot with just the Western Digital Win98se works fine. The only thing I haven't tried is to make Win98SE my master and XP my slave, but I don't want to do that, because i primarialy boot into XP. I only use 98SE for older games such as Tomb Raider.
Anybody got any ideas of what is happening?
