Hardware Monitoring
Which software does everyone use for hardware monitoring in Windows7?
I have a new computer and would like to know what new gadget software everyone uses these days.
haha yes it does, but there was definitely some reason I liked it better.. just can't remember what it was right now!
If it can display CPUTIN correctly then that gives it a leg up right there. I'll take a look and see if it does later.
I use what came with my mobo (OC Tuner). Works fine, reads all my temps and fan speeds, lets me tweak CPU & RAM particulars from a GUI.
The problem I been having with hwmonitor is that it doesnt reset the min/max on core temps when I hit the reset button. Everything else resets just not core temps. shrug. I will try that clone.
http://www.hwinfo.com/download64.html
