Hi All...
I'm having what I THINK is a hardware issue. At first I thought it was a virus (or whatever). I have scanned and scanned and scanned my system. I have a resident, active antivirus program that is updated at least once a day (AVG), and I have several others I use to run scans anytime I'm going to be away from the computer. I keep the system clean, and not junked up. It's defragged and cared for. I've had this box for (and I know what you're thinking) about 7 years, maybe 8, or 9 even. It has a master/slave HDD set-up and I just added an external USB drive in the last few months.
The OS is XP Home. I keep that updated as well. I'm not really a gamer, so I don't have anything taxing on it.
So, a couple days ago it suddenly started running slow. the UI was a little jittery using the mouse, like something was running in the background, hogging up the resources.
I have several utilities that shows all the running processes and so forth. I didn't notice anything 'suspicious'.
I ran many scans, both in normal mode and safe mode. Nothing has turned up.
After doing this a few times booting and re-booting I started seeing a message during the boot process that says something about an IDE cable 80 or something not installed. I've never been able to see the whole thing as it doesn't stay on long enough.
Believe it or not, but I do actually take the cover off the box and clean it from dust every so often, so it's not horribly dusty, and when I do I'm very careful.
I've never seen this message before....don't know what it means, but wonder if this has anything to do with the sluggish behavior.
When I listen to streaming radio on the web the sound is jittery, like the computer just doesn't have enough balls to drive it...if that makes any sense.
Like I said, it's been a good system. I've kept it up, it never gets moved, and I'm the only one that uses it.
I don't think it's a virus, and now I think it's this hardware thing......does anyone have any idea what this is about, and obviously....how to go about getting it corrected?
By the way...if anyone needs it, I have a CPUID text file of the system I can past here.
Anyone?.....ideas?....help!
Thanks
Thanks
