BonzaiDuck
It's still six months later from the time I posted here saying I would build a Core-2-Duo with the ASUS P5WDG2-Ws-Pro motherboard. I've looked at various options including the 680i boards, and I keep coming back to this one.
In addition to the stability, proven over-clocking and other features, I wanted to use the Pro board because of the PCI-X slots. And I do not plan to build an SLI or Crossfire system (although the Pro provides for Crossfire) -- a high-end nVidia 8800 GTX or even GTS is more than I need.
The idea was to open up the SATA2 bottleneck as much as possible with hardware RAID5. I've looked at the results for sustained throughput with PCI-X RAID5, and the sustained throughput for the individual drives I want to use in a four-drive array. The array will be almost as fast as an array using WD Raptors.
But I also see that there are PCI-E RAID controllers available, with a four-port card running at PCI-E x4. I'm pretty sure that running such a card in the Pro's second slot will degrade the video to x8, so I'd have to pick either an ASUS "Wall Street Quartet" or a 680i motherboard to use a PCI-E RAID card.
How much of an improvement in disk throughput -- if any -- would I have in using a PCI-E RAID controller over a PCI-X RAID controller?
