Hardware Burnin Test for Large Memory System
RMSe17
153
Hello!
I am trying to run a burn-in test on a new computer with 60 cores (4x E7-4890 v2) and 1.5TB of RAM to make sure the system is stable. What do you guys recommend to test this?
I tried booting into WinPE 5.1 and ran prime95 x86_64, but if I select 60 threads torture test, the application instantly crashes with some memory error. I am not sure if this implies DOA for some of the RAM sticks, or if the program can't properly handle a test of this size. If I select 40 threads, torture test seems to run fine. If I select 45 threads, it seems to run, but app crashes if I try to exit it. At 50+ threads, instant crash.
I am not sure if this belongs in another section, but I figure since my actual goal is hardware testing, might as well put it here.
Thanks!
Ken g6
Moderator
Dec 11, 1999
16,838
4,817
75
Hm, PrimeGrid (see my sig) would run a similar test to Prime95, but with many small processes instead of one process with lots of threads. Your system would also be very good at, say, Folding@Home, which would provide a test with more IPC.
As for Prime95, maybe you should ask the author if there's a problem. I can't recall any specific instance of a user with more than 24 cores.
mfenn
22,400
www.mfenn.com
As system like that should have some sort of BMC with an event log. Pull that up and see if you see any memory errors corresponding to the crashes.
Burpo
4,223
473
:eek:
