- Jul 16, 2003
- 424
- 13
- 81
Greetings,
A lawyer who is a friend of the family asked me to upgrade and setup his office network and I was hoping to get some suggestions. I need to build 3 workstations and 1 server. We'll be using a wired network off a cable/dsl router. The things he needs is MS Office, ProLaw, and some kind of group calender so I figured I could setup exchange for outlook. As far as backup is concerned I thought dvd-r media would be more than enough and simple since everything is pretty small (text documents, forms, etc.). I've gone ahead and looked up some prices on the hardware and software. If you think I should do anything different or if you think I got everything right for the most part I'd really like to hear it. At first, I thought about going all athlon64 w/nforce3 mb's for both server and workstations but someone in irc thought going intel might be better for less heat?
1 Server
Hardware:
P4 2.8E $180.00
ASUS "P4P800 SE" i865PE Chipset Motherboard for Intel Socket 478 CPU -RETAIL / $89.00
Corsair Value Select (Dual Pack) 184 Pin 1G(512MBx2) DDR PC-3200 - OEM / $160.00
16X DVD-/+RW Drive for backup / $72.00
ENERMAX Black 10-Bay ATX Mid-Tower Case with Temp Display and 350W Power Supply, Model "CS-30881TA-B3A" -RETAIL / $53.00
Western Digital 80GB 7200RPM SATA Hard Drive, Model WD800JD, OEM Drive Only / $69.00
Geforce FX5200 / $50.00
Software:
Microsoft Small Business Server 2003 Standard Edition - OEM / $438.00
Microsoft Office 2003 Basic With Service Pack 1 - OEM / $173.00
ProLaw Ready (http://www.elite.com/solutions...-fam/prolaw/index.asp)
3 Workstations
Hardware:
P4 2.8E $180.00
Corsair Value Select 184 Pin 512MB DDR PC-3200 - OEM / $79.00
SAMSUNG 16X DVD Drive Black, Model TS-H352A/WBGH, OEM / $25.00
Software:
Microsoft Windows XP Professional With Service Pack 2 -OEM / $145.00
Thanks in advance for any suggestions,
Erik
1 Server
Hardware:
P4 2.8E $180.00
Software:
3 Workstations
Hardware:
P4 2.8E $180.00
Software:
Erik
