I received a hardrive from a friend today so i tried to hook it up, i got the connecters right , and everything but when i would connect the second drive that received from my friend my pc wouldnt boot so i took the second hardrive out of my pc and then my pc booted fine , then while i was in windows i plugged in the second hardrive, and my pc shut off, just like it would if the power went off, so i removed the second hardrive comepletly this time when i started windows it asked me i wanted to check the hardrive for errors so i did think it was a good idea so i let it check the errors, the thing im not sure about is if my pc shut off while it was checking for errors or after but it shut off and now it wont start windows....If i restart windows starts to boot and i see the "windows loading" but once its about to open the logon my pc gets a blue green and shuts off.........
Im on knoppix right now and my hardrive apprears to be working cause i can access my files but i cant see to load windows correctly ......I tried loading the windows recovery console but when i did i didnt see any options on how to recover.....I tried the the check for errors option and it said it didnt find any......thats all i could do cause i didnt know what else to do........
How do i fix my pc now ? is it possible to fix this without losing my files......can i check for errors with knoppix ?
thanks in advance
thanks in advance
