- Apr 21, 2001
- 1,197
- 0
- 0
When I first installed Windows 2000, I installed it on my second harddrive and I decided to format the drive in NTFS mode. I also had Windows 98, and I didn't like 98 not detecting my second harddrive, so I wanted to format back to FAT32. To do this, I went back into Windows Setup and tried reinstalling Windows 2000 back on the same drive. When it asked which drive ti install 2K in, I decided to delete my NTFS partition, so it would allow me to create a new partition and format it in FAT32. I deleted it and created a new partition of the same size. After that, I decided to install Win2k in the Unpartitioned space. It then asked whether I wanted to format it in FAT32 of NTFS, so I chose FAT32. Then it tried to format my drive, but then for some reason it couldn't. Then I decided to format the drive using my Data Lifeguard tools that came with my Wester Digital Drive. I booted the floopy disk and went in the program and I asked me which drive I wanted to format. I chose the appropriate drive. Then it did a BIOS check and said that "Device 2 could not be accessed." Now, I cannot format my D:. Does anyone know why this is happening and help me fix the problem?
