Harddrive problem
Terranboy
150
When I turned on my computer today, in the middle of the post screen the harddrive made a click sound like it does when I turn it off. Then I hear the drive power up again, then it'll make the click and do it again over and over. So I rebooted and if got a little further in the boot up and did it again. Over and over clicking and powering up. (it stops booting up and freezes there). I turned it off again, and back on. This time it clicked once, powered up again and I was good to go.
Like I said, it is the same click sound it makes when I turn of the computer. Although I have heard it before. Sometimes when I take the side off my case to tuck a wire back somewhere that fell or something, sometimes it will make the click when I touch a power cord, and then if froze up usually. I only TOUCHED it, I did not move it. So at that point I just thought the molex connector was coming loose when I touched it and freezing up the computer.
I have two drives, a Maxtor 40gb, and a Western Digital 80gb. What is the problem and how can I find out which drive is clicking?
johnjkr1
2,124
Did you try running the diagnostic on the drive from the drive maker? I would start with that.
Terranboy
150
I don't think its the PSU. I've gotten a new one since the clicking by touch started and now I'm running a Antec TrueBlue 480watt.
Can a static discharge restart a HD?
Terranboy
150
I need some help here. Its doing it more and more. I ran some diags from Wester D. Checked out ok. I ran some tests on the Maxtor and it made the click during the test, but it passed the tests it said, then I ran it again, and it errored out twice. Then I rebooted and it took foooorever to load up. So I decided to install Mcafee to scan for viruses. And it won't install because it says I need at least 8,000kb of drive space, and I have 10.1gb free on that drive. It won't install on the other drive. Heeeelp.
*crosses fingers* Please don't be hardware failure Please please please!!!
VirtualLarry
56,587
10,227
Originally posted by: Terranboy
*crosses fingers* Please do be hardware failure Please please please!!!
Hmm. First time that I've actually seen it *wished* that problem hardware would fail. To each their own, I suppose.
moonsite
692
To me, it sounds like your drive is going. Might want to move your OS to the WD drive.
