Harddrive Cooling Question!
Rhombuss
1,544
I know with the first generation of 7200 RPM IDE drives, cooling was a good idea. This is the same case with first and second generation 10000RPM and 15000 RPM SCSI drives. But now that the platter sizes have increased a great deal (40GB/platter and up), is it necessary to use aftermarket cooling for the newer IDE drives? Say for example a 40GB and 80GB, is it really necessary to cool these drives? I've even seen some cooling stores stocking watercooling gear for HDDs, I think that is a total waste as they don't even put out that much heat (in comparison to CPUs).
What are you thoughts? BTW - I'm planning a custom case so I need some input whether or not to implement HDD cooling ;).
TIA!
jiffylube1024
7,430
Depends how hot the HD's run. As long as they're not scorching, and you don't have like 3 10k rpm drives all beside one another in your case, you should be fine.
Rhombuss
1,544
That's interesting...I didn't think a small cooler like that would make a 16.6 degree difference in the temperature. SnowPunk, what harddrive did you use in that testing? Also, can someone answer my question about the necessity of cooling with the newer 40GB/80GB platter HDDs? I hear they run much cooler, particularly at 5400 RPM.
TIA!
Zap
22,377
7
New 7200RPM drive shouldn't need cooling. They run a lot cooler than ones from a few years ago. Besides having reasonable case ventilation, leaving an air gap above and below the drive would work.
Rhombuss
1,544
That's what I thought Zap - so cooling shouldn't even be an issue for the new 5400 RPM drives correct?
nexus_7
Banned
Feb 6, 2001
1,064
I use This on all my scsi drives. it is pritty quiet and extreamly well priced. Oh and it cools liek a mofo. :)
Greg
Zap
22,377
7
<< so cooling shouldn't even be an issue for the new 5400 RPM drives correct? >>
Correct. They'll barely get warm.
