I've jsut downloaded SpeedFan 4.20. It doesn't support my mobo but it does give me temperatures for more or less everything. According to the program my HD2 is running at 65-70 degrees celsius, but, te other hard disk HD0, which is the same model is running at 35c. Do you reckon this sounds accurate? Shouldn't it be called HD1, or has it changed the label because of partitioning on my harddisk? The rack hold the diskdrives does feels warm, and the hot harddisk is in between the HD0 and FD0. I'm going to separate the harddisks further in a moment.
This Speedfan program is also giving random temperatures for Fan03 - ranging from -8 to 80 degrees c. I have no idea what fan this is - Only one of the fans is on a tachometer, and I'm presuming it's Fan02, but it's only registering 0RPM, the other case fan is on a 12v line but it seems to be giving an wavering 893RPM
Can someone tell me if any of this makes sense please?
Thanks
Thanks
